Creating surfaces from a Farro arm scan.
  • Thread starter Thread starter dvancleve
  • Start date Start date
D
dvancleve
Guest
We have body components that we scanned with a Farro arm. I imported this into pro as an IGES. Is there an easy way to use the IGES curves to create datum curves? I want to use the datum curves to produce a surface.
yes ...
create curve composite -> Exact/or Aproximate ... and you select them.
yes ...
adicar@home.ro
the best way I do it is use High Res software which works on top of Pro/E .You can directly get the curves or points in Pro/E and the good thing is that the curves are editable.For more details go to www.reverse-it.com.
