creating surface from datum points
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hi all,
I have series of about 4950 points that are the coordinates of a 3D surface. The points are layed out in a rectangular manner. I wish to place a surface through/on these points.
I've tried putting datum curves through these points, but I can only make the curve (it seems) with splines- which is not what I want. because then the surface curves upside down through the Z ,Y coordinates..
Any suggestions as to how I can lay a surface along these points?
Any ideas?
Are you doing the first direction and second direction?
Scratch my reply!! Goodluck!
you could do that easily with restyle.
The only problem is they want 15k for the module.
I think they have a 90 day demo if that helps.
Mike
Yep..
Your going to have a lot of work.
