A
andrewyair
Guest
Can anyone offer me advice on the best way to create dished features in ProE? The image below hopefully shows what I want to achieve - I've cut a straight extruded hole through a fairly complex surface and I want to fill this with a recessed dimple.
What, in users' experience, is the best way to create this type of feature? I've always tended to go for boundary blends by creating a central curve to control the depth of the dish and creating a pair of semi-circular features as shown below:
However, even when adding a tangent constraint on the second feature, ProE creates a nasty 'pinch point' at one of the intersections as shown below:
This prevents the model from solidifying, as well as having obvious visual ramifications for the produced part. I've tried using a variable section sweep witheven less success(see below) and am a bit stuck for ideas so any help would be much appreciated.
Thanks, Andrew.
Thanks, Andrew.
