Creating df
  • Thread starter Thread starter Hitt
  • Start date Start date
H
Hitt
Guest
I'm using W2 Adobe Acrobat 5.0. When I create the pdf the line weights on everything is heavy and difficult to read. I can print the pdf and it looks ok but viewing it is ugly. I've read all the previous discussions on the subject and I thought that creating a General Postscript file and then opening it with the Adobe distiller would be the answer, it didn't work the result was the same. Anyone have a different solution?
Use pdf 995 instead of Acrobat 5.0. Im using pdf995 to write pdf and acrobat 4.0 & 7.0 to read pdf. In the lower version u will see the difference in the line weights when u zoom the particular area. But in the higher versions all line weights are clearly visible according to the line weights u hav given in Pro-E when zoom extents.
