Creating and unbending a sheet metal component
  • Thread starter Thread starter rajapurrajeev
  • Start date Start date
R
rajapurrajeev
Guest
I am new to solid works and I am in a fix. I have a component (Attached here) i need to create the same in solid works and unfold it for development drawing. Can somebody help me with instructions to do it?
ThanksView attachment 6509
Steps for creating this item
You will need to start with a flat rectangle. Then insert a 180deg bend in the middle with the radius you need. This will give you the U shaped part.
Now create a cut to split the top flats from the bottom flats.
Insert a sketched bend with the same radius.
See attachment
