Creating an unexplodable block
  • Thread starter Thread starter Alban
  • Start date Start date
A
Alban
Guest
I found in the Block creation dialog box, there is a radio button for "allow exploding". This is great, We have a LOT of blocks that I would like to set as not explodable. What I would like is to be able to modify that parameter for the existing blocks. I looked in the new Block Editor and nothing there. Any suggestions.
Thanks.
You can do it through the Block dialog. Select block name from the drop down list and uncheck "Allow exploding" checkbox. You also have to click on "Retain" radio button to make sure you don't insert it again on the drawing.
Cheers!
