Creating a crimped end on a pipe
  • Thread starter Thread starter Kirk115
  • Start date Start date
K
Kirk115
Guest
I'm seeking help creating a crimped end on a pipe. I was trying to do a loft between two sections, (one section is the original pipe and the other being the crimped section) but for some reason the loft won't generate.
Any ideas of what I can do?
Attached are pics of the part I have at the moment and what is trying to be done.
there are two errors I am getting when lofting are either
1st: "the feature could not be created because it would produce self intersecting geometry" which is when I select the OD of the pipe and then the surfaces all around the smaller surface
2nd: " the end sections for a loft must be either planar or 3d faces or surfaces. A 3d section that does not bound a face or surface cannot be used as an end section." this is when I select the OD of both sections
I'm not very experienced with the loft feature so I could be doing something wrong.
using SW2019
