Create relations
  • Thread starter Thread starter arno21000
  • Start date Start date
A
arno21000
Guest
I've got an another problem, I want to create a new relations into my model. I want this action automatizated.
In think it's possible only in JLink, because the problem is, using a mapkey, this action delete all existing relations.
I want to to this because, I want to add new relations into older models.
Someone got an idea?
In the Jlink documentation, you can find an code example :
<H4 =ing3><A name=17></A>Example 1: Adding Relations between Parameters in a Solid Model </H4>
There is a specific item for relations under the documentation
I saw this example yet, but this example explain only how to create parameters and no adding relations. Or I don't understand correctly the method.
Does anybody already know how to insert an extra relation into the relations by use of a mapkey, without deleting all other existing relations?
We are still using WF3.
Thanks in advance
I had the same problem, and found a way to add relations without messing up existing relations.
In the relations window select Edit/select all/cut. This keeps the relations on the clipboard.
Then File/Import relations/ browse to your new relations in a text file and import.
Add an enter for an line space then edit/paste.
Then you will have your imported relations at the top with the original relations below.
If you added a relation like DONKEY="MULE" and verify the relations, this would add a new parameter named DONKEY with the value MULE.
Wali Crawford
South Africa
Thanks, this works fantastic!
Unfortunately, today it isn't working anymore! The problem is that ProE only inserts the relation which I have initially cut during the recording of the mapkey.
Zippy38, is there a chance that you can record me a mapkey to insert this relation:
pro_mp_alt_mass=floor((pro_mp_volume * pro_mp_density)+0.005,2)
Than I can insert this mapkey in my config.pro and test it.
I don't know what I'm doing wrong.
And another question: if I'm changing the txt-file with the relation which I want to insert, ProE isn't changing this in the mapkey. Is this normal?
Hello Zippy38,
did you have a chance to take a look at this?
