cpu fault
bogiejr
1
Does anyone on this site know how to clear a cpu fault on a allen bradley slc150 without a handheld terminal?
Pulling the memory backup battery on the SLC500 usually clears all clearable faults. Requires an application reload though, which I gues is what you're trying to avoid?
image.php
I don't suffer from insanity. I enjoy it...
Normally when this happens you either lost the program stored or your CPU, If backup battery is dead and someone powers down the unit you loose memory. Otherwise a connection with laptop
and appropriate software is best.
Chuck
Getting older is inevitable
Acting your age is optional
