Cosmetics - yes I know nobody like them
  • Thread starter Thread starter muadib3d
  • Start date Start date
M
muadib3d
Guest
Hello
I really would like to not have this problem, ahhh....
Ok. There is a drawing with a view of simple shaft.
The shaft has two cosmetic threads from each side. On one of them the cosmetic is shown on other nor. Look at picture.
Anybody has idea why?
hi, try to change the view orientation, for example if you've choose top view, try with the front view.
Bye !
Giorgio
thanksa xriddler
the problem is already solved
it occured that the thread surface was choosen from chamfer
as you can see at the screen there is a chamfer at the beggining of shaft
this chamfer was made before codmetic
unfortunately chamfer was choosen as the thread surface and that is the cause of the problem
Which makes cosmetic thread a really SMART feature if you can apply it to a conical surface !
Alex
muadib3d said:
thanksa xriddler
I was thinkin the same, but it was strange that the thread was not shown from the chamfer to the middle of the item...
In any case, it was solved ! :-)
Yea
at least(it seems) one thing that is not directly fault of cometic feature:))))
