Corrugated/Ribbed Hose Modeling
  • Thread starter Thread starter proescott
  • Start date Start date
P
proescott
Guest
Hopefully this will be an easy answer for some of you who are more experienced with PRO\E's advanced modeling features than I am. I need to model a flexible corrugated rubber hose similar to the picture shown below. I have tried several different ways but seem to be striking out. What is the simplest way to create this so that it is easily modifyable in the event that the hose bends need to change? I am using Pro/E 2001.
Has one of them been a VSS with Sketcher relation something like ...
sd(circle diameter) = 2 + .25 * sin(50 * 360 * trajpar)
Jeff,
Thanks for the response to my question. No i have not tried what your suggesting. I found a ptc tutorial at the following link http://www.ptc.com/appserver/wcms/standards/textmultitextimg .jsp?&im_dbkey=8460&icg_dbkey=382 which seemed to work to create a bent spring similar to what I am trying to create but I had difficulty trying to change it from an openbent spring to a solid hose. Do you know where I could find a step by step tutorial on the method that your suggesting? Any help you or anyone elsecan provide would be greatly appreciated.
