coordinates of a point
  • Thread starter Thread starter simo
  • Start date Start date
S
simo
Guest
hi to all,
someone can tell me how can I know the coordinates of a daturm point created for example as intersection of two curves? How can I create a daturm point with known coordinates?
thanks
Simo
hi
there is not a direct way to place a point with x,y,z parameters.
Create three planes in purpose to use the three surfaces option to create a datum point.
if you want to create a curve that passes through a number of points you can write the x,y,z, parameters to a *.tbl file and create a curve from this file.
hope this helps
xcad
hi
hope this helps
xcad
you could create a datum point using offset from coordinate system and enter x,y,z cordinates.
if you have an existing point on a curve you can measure the distance from a coordinate system to the point or visa versa and use the coordinate system as your projectiona plane. This will give you xyz coodinates. Further you can save this as a analsys feature and extract the xyz parameters.
Hope this helps
First-things-first, measure your point ordinates.
thanks to all,
bye
Simo
