Converting two way linear motion into one way rotation 2
DarinSelby
5
I have recently come across this mechanical animation.
How would this beveled, helical spiral be 3D printed?
The video was made in "Autodesk Inventor".
This Spring Toggle Mechanism is out of synch a little bit. It is the closest that I could get in ezgif.com
Imagine the red follower roller cams at the ends of the spring toggle mechanism. Here is a look at the follower cam:
Would someone be willing to attach these two separate animations into one?
Or, at least explain how that could be done?
Thank you.
Regarding the silent motion in one direction, several companies make what they call "one-way bearings". I have used them in the past, and if properly applied they work well.
1> why wouldn't you just print them in the orientation shown?
2> rather than ridges, why wouldn't you make V-grooves?
As a side note, the older 5.25-in floppy drives used a spiral to convert rotation into linear motion.
TTFN (ta ta for now)
What do you want this design to do? There are much more efficient ways to turn linear motion into rotary.
If you absolutely want to stick with this concept, you can look at push screwdrivers for inspiration, you just need something to toggle the switch at the extents of travel to make the push and pull cause rotation.[URL unfurl="true"]https://www.amazon.com/Eazypower-81966-9-5-Inch-12-Inch-Screwdriver-One-Inch/dp/B0010XV0B4[/url]
Looks like a Yankee push Drill
Thanks for all the good feedback. I'm doing some more sketches, so you'll be able to see what I'm trying to do with this.
Now there's something to look forward to :)
