Converting second order ODE's to First Order
Tygra_1983
Student
Oct 8, 2021
125
Hi Guys,
I have a basic understanding of converting second order ODE's to first order ODE's when you have for example, y'' + y' + y. However, I am stuck if you have a differential equation with just y''. For example, y'' = -f(L-x). How would I convert this equation into a set of first order ODE's?
Many thanks in advance
Again that is of the form y'' + y' + y. Thanks anyway.
Yes - so do it with the coefficient of y' = 0.
Sorry 3DDave, could you explain further on that?
Why is it no 0*y instead of a*y, as there is also no y variable?
I'm guessing there is no solution. I see no references to that case.
You should be able to integrate twice.
Double integration is the way..
When you write differential equation and search, one of the outcomes , the following web site ..
Write your D.E. y'' = -f(L-x) , the solution is the following pdf . doc.
