Conversion from ProE to Catia
  • Thread starter Thread starter Synergy
  • Start date Start date
S
Synergy
Guest
Could anyone out there please tell me how to convert a ProE part into a Catia part? If after conversion, are the features remained, and could I still edit on that model in Catia?
Thanks in advance.
Synergy
If the ProE part is solid, take a STEP output and import it into Catia. If it has surfaces, IGES output would give a better result. If you do this type of translation, you get only a dumb solid in Catia. This means that you cannot edit the model in Catia as there would not be any features. For more information on translators I would suggest you visit the website www.cadcam-e.com.
Julian
You can use the (*.ct) export option
Here's some information I dug up from PTC's website:
About Exporting to CATIA
Pro/ENGINEER supports the following types of CATIA export files:
