Convergent body still being created
danOOOO
Automotive
Dec 2, 2011
9
Hello All
I have turned off (treat degree 1 Spline as polyline) several times.
Restarted NX and (treat degree 1 Spline as polyline) comes up as toggled off and
it is still converting everything to a
convergent body? SOS
Anybody have any suggestions. Just started happening out of the blue. Today
Thank you
Can you explain what happens after the spline ?
You create a spline, which becomes a spline and not a polyline and then you .....? which is a convergent body.
Which version of NX ?
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.:)
Check the model template file. I'm not sure if "treat degree 1 Spline as polyline" is a part setting, or not. If it is, you'll need to change it in the template file (aka start part, aka seed file)
-Dave
NX 12, Windchill 11
Good point Dave!
If you are using a template part when creating new parts, you need to change that setting in these templates.
( I noticed the same when trying to change the default density. - It's not read from Customer defaults when one uses templates, only when using the "blank" option in File New.)
Tomas
