constraining nightmare
  • Thread starter Thread starter spider007
  • Start date Start date
S
spider007
Guest
in the picture below, two purple blocks in product 2 are constrained only with the offset in between them. I constrained the other two blocks (part 3's) to each purple block.
Now theoretically, you could create a parallel constraint on the top of the two white blocks, and straiten out the purple once.
BUT IT'S NOT WORKING THAT WAY.
what am I doing wrong.
I also attached a zip file with the blocks in question.
  • constrains.zip
    constrains.zip
SPIDER007
First select Product two then use the Flexible/Rigid Sub-Assembly.Then apply your constrains to achieve your required results.
does that mean that i have to blow away all the relevent constraints and redo them with that thing on.
Not Sure but I dont think so....Sorry Im not @ a workstation to try it out and confirm for you..Sorry
