config.sup
  • Thread starter Thread starter Mr.Plastic
  • Start date Start date
M
Mr.Plastic
Guest
Hello All,
Any advice on what type parameters should I include/ excludein my .sup file.
for example:
start-part,asm,dwg file path
library,texture,symbols file path
exclude: mapkeys?
I just not sure what goes in the .sup file
Thanks for your help
mr.p
We put very little, others put a lot. Definately no mapkeys.
save_object_in_current no
override_store_back no
company_name
Only need to be things you definately don't want users to be able to change, we let users change most things if they need to. They typically don't change anything.
Edited by: dr_gallup
Thank you dr_gallup
Thats what I thought- very little
mr.p
Hi Mr.Plastic,
Config.sup this is file it can saves the system colors,
Gopal Kulkarni
Hi friends,
can anybody please tell me where to find config.sup and how to edit it.
Thanks and regards,
Mudassir Khan
config.sup MUST be in your <proE_Loadpoint>\text directory.
By default the file is not there, you have to create it.
Use config.pro settings that you NEVER want your users to change. Do not put config.pro settings that can have multiple entries like mapkeys, def alyers, etc.
Thanx looslib, i will just give ita try.
Best Regards,
It is just a text file, use any text editor.
