Hello user
Try these :
To change the text height in dimensions go to :
Advanced, Draw Setup, and change the drawing_text_size parameter to the value you want. This change affects the dimensions height (if you have dimensions you can see that changes activated immediately).
To change the font style you must change the default_font parameter (again Advanced, Draw Setup) and write arial to the default font value.
If you don
