Config Option for Component Operation/Cut Out Result to be NOT dependent?
  • Thread starter Thread starter greatwhitewing
  • Start date Start date
G
greatwhitewing
Guest
I need to a LOT of these cuts as I increment dimensions to get progressive cutting. I am trying to use a mapkey but the cut out feature has a default of dependent which is NOT what I need.
I cannot find a config option to make the default not dependent. Having to this manually is very time consuming
Is there a confog option to uncheck the box under the options tab when redefining the "cut out" feature?
If you are just incrementing dimensions why not make a pattern?
