Gus14
- Mar 21, 2020
- 194
Recently, I was consulted on structural plans, where all concrete beams where designed as simple beams where top reinforcement ended at the support and did not continue over the support into the adjacent span. In theory, although the structure will not fail, if beams where designed as simply supported, cracks over the support are expected due to the negative moment resulting from continuity of the concrete during construction.
However, my questions are;
1) What does ACI think about this ? is it allowed ?
2) How would the structure behave under a seismic action ? ( with references )
3) Could the court expert committee regard this as unsafe and sentence a substitution ?
