structSU10
- Mar 3, 2011
- 1,062
I am looking at a condition where a cast in place concrete wall was cast against an existing wall one floor at a time. The existing wall is a multi-wythe masonry wall. I am getting more info but assume they had form ties between the inside formwork and the existing wall.
I want to see if this concrete placement damaged the wall but need to see what makes sense for analyzing the 'locked in' wall stress due to this effort. We get a pressure from the concrete during placement and the wall deflects due to that pressure so I would think at least some - or all - of that stress 'stays' in the masonry as the wall never rebounds as the concrete took the shape of the deformed wall. If that is the case as you move to the next level of placement there would be a compounding affect from the previous form pressure and the next lift. For the next lift the composite wall assembly (existing masonry tied to concrete) resists the new pressure and I combine the original wall stress with the composite wall stresses.
I want a sanity check that I am not overcounting the concrete placement forces effect on the wall. Any thoughts / comments?
