engr2GW
Petroleum
- Nov 7, 2010
- 308
When a compressor goes down or stops running, it seems the fuel gas or start gas continues to flow, does the compressor have an inbuilt system that stops taking the fuel gas or start gas? Some other engines have fuel injection systems that are run by the running of the engine (or part of it), but the fuel and start gas of a compressor is supplied (typically in the oil field) by an external source, usually gas from the facility the whose gas the compressor is compressing.
So apart from designing the fuel gas header to shut in when the compressor stops running:
1. Are there compressor system that ensures that no more gas intake happens when the unit is down?
2. If not, can continuous gas flow into the unit cause fire or other problems?
Thank you.
As much as possible, do it right the first time...
Thank you.
