COMPRESS thickness of shell parameters
somacast
88
I wanted to ask about the weight used in the report in different loading scenarios, for example in the report shell thickness under (operating, hot & new, wind, bottom seam), tw which is due to weight they used a weight of 57,011.8 kg , while the shell weight only as a component is only 24,580.3 kgs, I do understand that they add other applicable weights associated with shell (shell#1 here for instance), however no matter how I try to figure it out manually from weights summary table I never get the exact figure, so if someone is familiar with this I would really appreciate explaining what all weights are being added in such case?
I have attached screenshots of relative data from the tables as an example here ..
Thanks in advance..
