Composite curves in WF2
  • Thread starter Thread starter venkataramu
  • Start date Start date
V
venkataramu
Guest
Dear Friends,
How to join the different curves to make it as a single curve (curve Composite option in 2001) in WF2????
Ramu
You have to select the curve, thena curve segment within that curve, then use the shift-key to select the curvesegment again as a base for a chain. Continue, withshift still pressed, andselect the remainin segmentsfor the composite curve. When all segments are selected, use copy-paste and you will have the dashboard for composite curves.
/Good Luck
Hi
then
Edit
Intersect
References
Define
and sketch sekond curve
Good luck
Here is another option that was posted to my question on another forum. I like this method best, because the picking isn't so contorted!
An alternate method (though similar) for picking the curves is to
select the first one as before (make sure it is bold red) then <ctrl-c>
<ctrl-v> and then in the dash board open the REFERENCES tab and
"details" then select the other curves in the "collector" This allows
you easier recovery if you mess up and pick a curve you didn't want.
ecirwin
Perfect
