ASME Stalwarts,
I'm working on a pressure vessel with a hatch that also functions as an unstayed flat top head. Based on my reading here, I get a hint that one has to work with the mandatory appendix - 2 and treat this as a loose ring flange. However, there is metal to metal contact with a central plate sandwiched between the flat head and the flange, which possibly leads to Appendix Y. Any advise on this one? Should I treat the flat head and central plate support as one?
Thank you.
SS304L Construction, 100 psi design pressure.
Thank you.
