G
gruhe
Guest
I am having a problem getting motion equations to compile in Pro/Mechanica. I have set the environment variable MM_C_HOME to the path of the compiler (Microsoft C++ version 6.0) and I get an error message that the equations could not be compiled and that it may be a system or installation problem. My operating system is Win 2000 Professional. Are there any other environment variables that need to be set? The model is set up with the proper joints, driver and ground part. I am using the Student version of Pro/Mechanica 2001 integrated with Pro/E 2001. The student version does not allow for Pro/Mech to be run as a stand alone program. I am wondering if this could be the problem? Thanks for any help you may give me on this.
Greg Ruhe
Greg Ruhe
