Company logo
  • Thread starter Thread starter dspaul
  • Start date Start date
D
dspaul
Guest
I am a entry level user and have a question on adding the company logo to a drawing template.
How do I add a jpg or image file to a drawing as a symbol?
Instructions on how to copy sketched geometry from one drawing (format) to another:
Group the entities together and give it a name. Under SHEETS menu, select “switch sheet”; then pick the entities again and once you have selected done. This will create a second sheet. Export this as a DXF file. Then import it as an appended model to the drawing you are moving to and follow the yellow brick road.
In case u are using Pro/E 2001 u can directly do it by Insert>>Data from file
In drawing: Insert>Object
then you are able to select your favorite file in order to insert in drawing.
To insert a jpeg,gif or tiff:
Select: Insert(pull down menu)
Object
Create From File
Browse
