Commandline window
  • Thread starter Thread starter Beauregard
  • Start date Start date
B
Beauregard
Guest
I have anchored my commandline window on the leftside. When I move the cursor over it as there are other buttons near it, the commandline pullsout automatically. It is quit irritating. Is it possible to make it such a way that I have to pull it out by clicking on it and not by just moving the cursor over it.
Thanks in advance.
Use ctrl+0 and the problem will be solved. Wait I am not sure whether it is ctrl+0 or ctrl+9 so try both of them and the problem will be solved.
Enjoy!
Turn off...
... the Auto-Hide function. You can keep it docked top, left, or right, all the same as it would normally be on the bottom. You also have the option to let it float, or auto-hide like other palettes. Is this what you needed? Good luck.
