combining different splines as one line
  • Thread starter Thread starter superamerica
  • Start date Start date
S
superamerica
Guest
i want to form a path on the surface of a cylinder, but i need to combine all of them as one line, cause i want the sketch to follow all of these paths and form a closed solid form. need help, thanks
i want to combine all of these splines as one line, cause i want sketch to follow this path and form a closed solid
use the JOIN command to attach several continguous curves into a single curve.
