palk7 EIT
- May 12, 2020
- 159
For Industrial buildings when I have long column (32' height). For determining column compression capacity, when I have the girts connected to the column outer flanges at 5' spacing and the Inside flange of the column is braced by Fly brace from the girts at Mid-height of column (16'). Can I consider the unbraced height of the column as 16' at the mid-height where both the inside flange and outside flange will be braced by the girts? for finding the compression capacity
Thank you
Thank you
