Column base modelling in ABAQUS (Stress distribution) 1
Daemon1
Student
CM
Hello everyone, the objective of my work is to perform a stress distribution analysis on a column base plate using a FEA software. Honestly, I don’t have a clear picture of how to accomplish this task, so any advice would be appreciated.
From the little research I did, I decided to perform a FEM analysis of a column-base model in ABAQUS and from there plot the different relevant graphs.
I drew my column-base model, created and assigned the following materials:
-S275 JR for the IPE 300 column
-S235 JR for the stiffeners, the base plate and the strut
(Actually, these materials and dimensions are from a real project I visited)
-I used concrete damage plasticity with compression and tension values as material property for the concrete block
After the assembly, In the step module, I created a loading step (In which I applied a horizontal displacement to the column top there by initiating a bending) while considering non-linear geometry.
In the interaction module
- I created the contact interaction property and used it to define an interaction in the initial step in which I issued a friction coefficient for all elements/parts touching in contact.
- Created tie constraints between stiffeners and baseplate, baseplate and column
- Created the embedded constrain between the part of the anchor rod buried in concrete and the concrete block
- Applied a rigid body constrain at the top of the column before applying the displacement
- Applied a rigid body constrain at the base of the concrete block followed by fixing all the displacements and rotations at the base to 0 (Fixed))
In the Load module
- I applied the horizontal displacement at the top of the column base with a ramp amplitude.
Mesh module:
- I meshed all the elements
Job module
I ran the analysis and I faced some problems:
- No matter the amount of displacement I apply to the column top, it seems like little to no stress is transmitted to the base plate
- I performed an analysis by changing the loading condition to axial compression but only the column was affected again, the baseplate had very little deformation and the concrcete none
I actually wish to see a deformation of the base plate especially at the level of the bolt and also see an effect on the concrete block. Maybe I made some errors and I don’t know them, I wish to get some help guys.
Also, all my analyses are static monotonic analyses
Here are some images of the results I got from the axial load and horizontal displacement loading cases:
I provided a little video for the bending behaviour. I think the displacement is so small because the analysis aborts all the time but I don't know why!. I have enough space.
Video Link:
Here are a few suggestions:
- increase the density of the base plate's mesh, especially in its thickness direction
- adjust the limit values of the contour plot to better see the stress distribution at the base of the column
- probe the values at the base of the column to make sure that they are too low
- make sure that all the interactions (contact, tie and embedded region constraints) work correctly and there are no unexpected gaps
- double-check the material properties
- if the above doesn't help, start simplifying the model and see how it behaves
Deamon, your model does not reflect what you are looking for.. If you are looking base plate and conc. pedestal stresses, it would be better to model only the pedestal and the base plate..
I will suggest you to look to the following doc.
 https://files.engineering.com/getfile.aspx?folder=eb34281f-52ed-4a6f-b0bb-9f895d3537cd&file=07-GB_Column_Bases.pdf
Thanks for the document, @HTURKAK. Please could you if possible explain how to define the interactions between the baseplate and the concrete so as to have a good working model
