collision problem....
  • Thread starter Thread starter camiel
  • Start date Start date
C
camiel
Guest
Well .. simple question (i hope).. how can i solve this problem? see pics below
Collision detection? how ? In mechanism?
I did some experiments withcontact regions in structural,but no luck either..
greetings Camiel
i dont think you have discribed your problem well.
collision detection is in mechanism. if you have 2 parts and during the
running of your setup there is a collision it will highlight the areas
of overlap for you and pause to show you.
if your analysising in structural you will only see if the part overlaps itself under your predefined loads.
hmm yea,well i just want good results to see the effect what happens.
So my question is, how can i get good results with collisions.. preferably in Structural. So how do i need to constrain it better then?
Or is that only possible in mechanism?
mechanism will not show you how your objects deform when hitting together. but will highlight overlapping entities
Camiel,
This could be a problem with the element size. You are not showing the mesh but what I will sugest is to increase the mesh density. This may solve the problem.
Luis
Well i did some experiments with contact regions and that seems to help a little... but i cant do a contact region analysis + large deformation... And thats what i need.
Ill post some pictures later on.. in a rush now
ciao
well another example...
This is a PP part, with a thickness of around 0.15mm i want to simulate it's movement... but OR i do a contact region analysis and it's not going through itself, but not large deformation analysis.. so no good... OR i do large deform but the thing above happens... And that's impossible off course.
So how do i solve this? or is it just impossible with Pro/Mechanica?
Thanks, C.
Edited by: camiel
With large deform:
or with contact regions:
So that's my problem, both analysis are not good, but mixed together i would be there. The contact region analysis is not correct as you can see... (compare it to the large deform one) The large deform does look good for the large flexibel part that goes down under the angle, but for the rest it's not good..
help!
hmmm still nobody who can help me with this topic?
The only explanation I have is to check your deformed view
settings. I know that mechanica, at least for me, has not always
shown accurate deformations. Maybe it's just that I work with
different parts.
I'll experiment a little and see if I can't come up with a better solution.
Has anyone come up with a resolution to this problem?
Or has anyone done any analysis of a multi-leaf spring?
I am currently working a problem with Composite springs. We are trying to predict spring rates based on multiple springs colliding and chaging the stiffness of the assembly.
