coextrusion
Gerard-E
CA
Hi all,
I am trying to find some information on copper + plastic coextrusion.
Can anyone explain how this process works?
Is the copper inserted in the plastic channel after it is extruded? I have samples where the copper is loose and free sliding inside the plastic, which suggests it is not actually coextruded as this would melt the plastic around the shape, hence hold it thight (glued)...and then some samples were it does seem quite strongly attached.
Also, could this copper plastic coextrusion be copper + any extrudable plastic. I think my samples are all PVC, whcih would likely be too rigid for what we want, since ideally we would like to ship this in 2ft diameter reels...
Any info on this would be much appreciated.
Gerry
Some are done by feeding the Cu insert into the plastic extrusion tooling.
Before you start thinking about reel sizes will your Cu insert coil that tightly without taking a set?
This image is just an example I found online, not the actual design.
can you think of any particular limitations as to the materiel type, design or other that could guide me on this?
Or if you know of specific sites that could shed some light on this?
Gerry
