gwalkerb
Petroleum
- Jul 4, 2012
- 74
I'm implementing pressure drop calculations in a number of internal sizing tools using the Darby 3-K method. However, a problem I'm running into is finding appropriate coefficients for the actual fittings that we use.
Does anyone know if there are any published coefficients other than what I currently have? My current reference is Table 7.3 from 'Chemical Engineering Fluid Mechanics - 3rd Edition, (Darby, Chhabra)'. But it seems like it is missing details for some of the B16.9 fittings that we commonly use. Any of the data I've found online also seems to just be a summary of this table. For BW 90 degree elbows, it provides data for r/D of 1, 2, 4, & 6 - my intent was to determine the actual r/D for any given B16.9 BW elbow (whether SR or LR), and linearly interpolate between the provided coefficients as needed. The r/D ratio is 1.5 for a LR elbow, but this is based on nominal size, not actual OD, and given that actual diameters are dissimilar from nominal diameters at sizes less than NPS14, the ratio is never actually going to be 1.5. I'm not sure if this is the best method, as the Ki and Kd coefficients are not monotonic across the r/D range, but I'm not sure how else to approach it. As well, because the Kf formula references nominal pipe diameter, and not actual pipe diameter, I'm wondering if that's what I should use for elbow definition.
For 45 degree elbows, it only provides information for threaded and mitered elbows. My understanding is that the Kf value for a 45 degree elbow is not the same as half of a 90 degree elbow, as the pressure recovery characteristics are different, but unless there's coefficients for BW 45 degree elbows out there somewhere, that's how I'll need to proceed.
For tees, the table lists threaded and flanged, but not BW. I am assuming that I can use the flanged coefficients for BW tees, as the design of a flanged tee is basically a BW tee with flanges attached. It's not clear how to approach reducing tees however. Should I calculate it as a non-reducing tee of the larger or the smaller size? Or is there a different approach? This would affect how I calculate my Reynolds number - I'm leaning towards using the smaller of the two sizes, as this is consistent with recommendations in the book when looking at reductions or expansions, but a reducing tee isn't quite the same as a straight reducer.
