EngDM
- Aug 10, 2021
- 708
I'm wondering what peoples thoughts are as far as performing certain checks that are outlined in a previous code edition, but then has since been removed in the current. Across Canada (at least for the foreseable future) some provinces specify different NBCC versions, and within the "Acceptable solutions" table they specify different editions of steel codes and wood codes (among many others).
If the older edition specifies a check, for instance HSS wall plastification due to a shear tab, but the newest edition basically says "well hey, after doing tests on this, the wall plastification was never actually an observed failure, just check plate moment instead", and they omit the plastification check, how do you proceed? Can one chalk it up to using alternate solutions and call it a day, or is it common practice to just check it anyways.
I guess a simple real world example is as follows: If a new grad came in and had the newest book, would they need to buy previous editions to access these checks and be compliant?
