CLT Diaphragm In-plane Shear Check Eurocode 2
otto_eng
88
Hi all,
There seems to be really good sources/references for CLT diaphragm design/checks in the US but not in Europe.
Does anyone have any good references that goes through all the checks for CLT diaphragm in-plane shear ?
Thanks !
[ponder][ponder]
I will suggest you to look to the following docs. There are worked examples..
- Holzbau Wände - Decken - Dächer (Von Prof. Dipl.-Ing. Horst Schulze )
- Holzbau Dach- und Hallentragwerke ( Von Prof. Dipl.-Ing. Gerhard Werner , Prof. Dr. sc. techn. Karlheinz Zimmer )
- IMO , you may need to look , Bauphysik-Kalender Holzbau ( Von Univ.-Prof. Dr.-Ing. Nabil A. Fouad )
He is like a man building a house, who dug deep and laid the foundation on the rock. And when the flood arose, the stream beat vehemently against that house, and could not shake it, for it was founded on the rock..
Luke 6:48
