Clash Analysis-Interference inside 1st level Assy parts need to be excluded in Report
  • Thread starter Thread starter thilag1981
  • Start date Start date
T
thilag1981
Guest
Hello Friends
While performing clash analysis it is producing the interference report with the Sub Assembly parts itself which is not required. For example if performing a Clash analysis for Engine then it produces the hard interference between the 2 parts inside the sub assembly called Crank shaft assembly.
Here the requirement is if any part which is first level BOM child in Assembly navigator of the engine then it should produce the hard interference in the Clash Report, but within the first level sub assembly hard interference is not required.
For example :
If there is any Interference between 2 parts inside a first level assembly (Say Crank shaft Assembly) then it should be hided since it need to show in that first level assembly (Say Crank shaft Assembly).
If there is any interference between the first level assembly and the part inside the engine then it need to be shown. i.e., Any part inside Crank shaft Assembly interference with the Engine Part Say Cylinder block.
If there is any interference between the 2 first level assemblies then it need to be shown. For Example Crank Shaft Assembly and the Piston Assembly.
If there is any interference between the 2 first level components then it need to be shown. For Example Cylinder Block and Cylinder Head.
Is there is any predefined settings or options in it. Or even after generated report is there any way to find, filter / figure out the interference inside the single first level Assembly.
Thanks in Advance.
