Circular Spring
  • Thread starter Thread starter Khurshid
  • Start date Start date
K
Khurshid
Guest
Hi guyes!
Any body may tell me the way to model circular spring using pro WF 2.0.
Khurshid
insert>sweep>protrusion...thats the simple version
Salam Khurshid,
Its very simple. Do the following steps:
  1. <LI>Sketch a circle of your desired dia.</LI>
    <LI>Click on the vss icon on the right.</LI>
    <LI>Now click on sketch toolbar.</LI>
    <LI>Draw a line from the origin and angle to the vertical line. Create two dimensions; one the length of the line say sd1 and the other angle of this line to the vertical. Make sure the line is in the first qudrant.</LI>
    <LI>Now click on Tools--> Relations and enter the following</LI>
sd6=trajpar*360*sd5
where sd6 is angular dimension and sd5 is the lenth of the line. Your sketch dimensions may be different than this.
6. Now click on ok.
7. nce again click on the vss icon on the right, and select the outer edge, it will select half ofthe circle, nw hold shift button on kwyboard and the select the rest half side.
8. Now click on sketch toolbar and sketck a circle with dia. of appropriate dimension.
9. Hide the first vss and first sketch in model tree and enjoy.
2005-04-21_214727_circular_spring.prt.rar
Resume it to see.
Israr
<B style="mso-bidi-font-weight: normal">Hi Khurshid<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />[/B]
<B style="mso-bidi-font-weight: normal">Salam alaik[/B]
<B style="mso-bidi-font-weight: normal">I think u want to make spiral spring that u say circular spring?? Am I right??[/B]
<B style="mso-bidi-font-weight: normal">Zaki[/B]
