Circular Spring by equation
  • Thread starter Thread starter amd450
  • Start date Start date
A
amd450
Guest
I would want do a spring around 360 degree, in the coordenate circular (I think), I want do this by equation. Are there a way to do this?
Thanks in advance
Andre Almeida
I THINK IS EASIER IF YOU USE A HELICAL SWEEP FEATURE FOR CREATING THE SPRING.
GO TO INSERT/PROTUSION/HELICAL SWEEP.
My friend, follow thse steps:
create a datum curve of circle of your required diamter
then make go to insert (pro/Engineer 2001) then surface then variable section sweep
now select datum curve you created first I mean circle
select done till you go to sketcher mode
from the intersection of the default references draw a line of say 20 units at some angle
then go to sketch mnu and click on relations
select the angular diamension say sd3
sd3=trajpar*20*360
select ok and exit sketcher
then ok
now go to insert menu then protrusion then sweep
select tangent option and select outer surface then done till you are in to sketcher
draw a circle of say 5 units
exit sketcher and
enjoy
Israr
Of course the easiest way to do this would be to download one of the many fine spring models off of Pro/E Central and just modify the parameters to your spring requirements.
Bill M.
You mean like this???
draw a revolved surface (straight line), then make a variable section sweep (straight line) from this surface (trajaectory) using sd?=trajpar*360*60 (or however many revolutions you want), then make a sweep of a circle following the latter surface...
Hope this helps...
Of course, after you get that first helix down, you can do this...
I'd upload the file for you, but it's over 38MB...
Thanks Bill, Miguel, Israr and Nose Bleed, what I needed do is similar the first image of N.Bleed. I dont know if I did any mistake, but of this way,N.Bleed. My VSS dont find one with other when rotate 360, stay a gap (space) between its.
Ill try again.
Andre Almeida
I'm still trying to figure out how to do it in Wildfire. Each time I pick the trajectory(s) it ends up giving me two starting points, which gives a space between each trajectory... Does anyone know how to do this in Wildfire?
My problem is similar Nose Bleed but i'm using the version 2001.
In 2001 you can multipick trajectories by holding down the CNTRL key and clicking on as many trajectories as you wish, then choose which direction you want your starting point to point from.
By doing this, the entire trajectory that has been picked is chosen as a single string, thus allowing there to be no breaks in the VSS..
AH! I figured it out - using the Shift key works a lot better than using the CTRL key in Wildfire...
I'll try use your tips. After I'll comment with u my results.
I tried hold the SHIFT key, after I selected the trajectories, when I inserted those relation appear a mistake, show me that this relations isnt valable. Could you tell me how do this? But step-step (for dummies).
Andre Almeida
I sent you some specifics... Let me know if you have troubles with my directions...
When u told me I undesrtood, but I didnt put everething in practice. This 2 trajectories that I did continue a gap between its (an intersection)
