Circular saw design help needed please...
  • Thread starter Thread starter cabellos
  • Start date Start date
C
cabellos
Guest
Im lost as to how i should design the bearing housing on the circular saw i am designing. From given dimensions i have so far created the saw, shaft, 2 bearings and v-belt pulley. But i need to put this all together now with the use of designing washers, and bearing housing etc. I really could do with some help so please provide e-mail address so i can send what I have completed so far.
If you want to send your initial drawings / sketches to me I will gladly help in any way I can.
35 years experience as toolmaker / designer in the water pump field.
robertl@rock.com
Robert Larson
Australia
Sounds Interresting
Send me the stuff that You have. I would like to look at it and help out.
I do what I can, to help you man! We had a similar work some month ago!
My email-adress is alexander.harbrecht@gmail.com
