Circled Y
Belanger
Automotive
Oct 5, 2009
2,450
I'm working with a drawing that follows ISO, and they have a profile tolerance with a circled Y after the tolerance number. Does anyone know what that means in ISO? It's not in any reference that I have access to right now.
There are actually two profiles: the upper tolerance frame has 1 mm with respect to datum B, and the lower tolerance frame has 0.4 (Y) with respect to the same datum B.
John-Paul Belanger
Geometric Learning Systems
I once got all caught up in an explanation for a circle E that I saw on a print at a customers plant. I went on and on about the envelope principle and what it meant in the context of the dimension it was associated with, when a student raised their hand and said "That's indicating the change made for rev E." I was totally embarrassed.
John Acosta, GDTP Senior Level
Manufacturing Engineering Tech
