choosing the correct structural system for 15m span slab
Hilal12
1
I am working on the structure of a large 3 story building that contains 15.5mx8m (columns to columns) slabs, the slab is supposed to be 25cm thick with no drops which till now I have not found any possible system or solution to make it feasible and propose for design (I am a newly graduated civil engineer).
through research and preliminary study I saw that what can be done:
- Making the 8m edges as main steel section beams (slimflor) with 40-45cm hollow core precast slabs connecting inside the beams and spanning the 15m. would result in total thickness of 50 to 60cm > 25cm.
- Using post tension that would results in 30~35cm thickness.
I have not studied either systems before, is what I am saying reasonable? is there any structural system for reaching the 25cm thickness goal?
also I am new to these forums so sorry if this was not the right place to post this question, thank you.
L/d of 60? Yeah, that's not happening for standard reinforcing**. Certainly not for deflection.
** I'm no expert on posttensioned slabs, so it's possible you could make something work with the right loading conditions and camber, maybe. But still seems far-fetched to me.
just call me Lo.
PT Generally works out around L/d = 40ish. 250mm over 15m is not going to happen with any material unless you’re building on the moon..
