Changing the Startup Directory
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
When Pro/E starts, the latest configuration files are read from the startup directory. This also becomes your initial working directory.
To change your startup directory, do the following:
1) In Windows, Right-click on the Pro/E short cut icon and click Properties
2) Change the Start in: field to the directory you want Pro/E to start up in
