Changing the Parameter Type (i.e. string to real number)
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Method 1:
Using the Model Tree: Create a column in your model tree under model parameters the same name as the parameter you want to change (this is a good way to enter values too). It should display the value of the parameter. Click on it and use 'backspace' to clear the field. Don't hit enter, just arrow (or pick) to a different field. If you pick on the (now empty) field of the parameter you just erased, it should give you a pop up to choose string, integer, etc. and you're off! I've seen it take more than once to get the field clear, so if it doesn't take the first time, give it another shot.
Method 2:
Using Pro/PROGRAM: Open the Pro/Program file. In the input section, modify the parameter type. For instance, if you have a parameter called HEIGHT that is an integer and you want to change it to a string variable, Pro/Program code will look like the following:
INPUT
TEST STRING
END INPUT
string_parameter="" + fam_inst_param_value /*to convert fam_inst_param_value to a string parameter
string_parameter_length=string_length(string_parameter) /*overall string_parameter string length
num_of_characters=string_length(string_parameter)
multiplier=1 /*sets default multiplier to 1
actual_value=0 /*sets default actual value to 0
/* Start - convert a 3 letter string into a real number
if num_of_characters>=3
multiplier=multiplier*1 /*change to *10 if more than 3 characters
if extract(string_parameter,3,1)=="1"
character3=1*multiplier
endif
if extract(string_parameter,3,1)=="2"
character3=2*multiplier
endif
if extract(string_parameter,3,1)=="3"
character3=3*multiplier
endif
if extract(string_parameter,3,1)=="4"
character3=4*multiplier
endif
if extract(string_parameter,3,1)=="5"
character3=5*multiplier
endif
if extract(string_parameter,3,1)=="6"
character3=6*multiplier
endif
if extract(string_parameter,3,1)=="7"
character3=7*multiplier
endif
if extract(string_parameter,3,1)=="8"
character3=8*multiplier
endif
if extract(string_parameter,3,1)=="9"
character3=9*multiplier
endif
if extract(string_parameter,3,1)=="0"
character3=0*multiplier
endif
actual_value=character3
endif
if num_of_characters>=2
multiplier=multiplier*10 /*change to *10 if more than 3 characters
if extract(string_parameter,2,1)=="1"
character2=1*multiplier
endif
if extract(string_parameter,2,1)=="2"
character21=2*multiplier
endif
if extract(string_parameter,2,1)=="3"
character2=3*multiplier
endif
if extract(string_parameter,2,1)=="4"
character2=4*multiplier
endif
if extract(string_parameter,2,1)=="5"
character2=5*multiplier
endif
if extract(string_parameter,2,1)=="6"
character2=6*multiplier
endif
if extract(string_parameter,2,1)=="7"
character2=7*multiplier
endif
if extract(string_parameter,2,1)=="8"
character2=8*multiplier
endif
if extract(string_parameter,2,1)=="9"
character2=9*multiplier
endif
if extract(string_parameter,2,1)=="0"
character2=multiplier
endif
actual_value=actual_value+character2
endif
if num_of_characters==1 /*if characters = 1, don't change multiplier
else
endif
if num_of_characters>=1
if extract(string_parameter,1,1)=="1"
character1=1*multiplier
endif
if extract(string_parameter,1,1)=="2"
character1=2*multiplier
endif
if extract(string_parameter,1,1)=="3"
character1=3*multiplier
endif
if extract(string_parameter,1,1)=="4"
character1=4*multiplier
endif
if extract(string_parameter,1,1)=="5"
character1=5*multiplier
endif
if extract(string_parameter,1,1)=="6"
character1=6*multiplier
endif
if extract(string_parameter,1,1)=="7"
character1=7*multiplier
endif
if extract(string_parameter,1,1)=="8"
character1=8*multiplier
endif
if extract(string_parameter,1,1)=="9"
character1=9*multiplier
endif
actual_value=actual_value+character1
endif
/* End - convert a 3 letter string into a real number
