Changing Pro's default text slant
  • Thread starter Thread starter MBuchholtz
  • Start date Start date
M
MBuchholtz
Guest
Does anyone know if Pro's default text can be changed so tha the text slant can be pre-set?
From your drawing setup file, you can specify default_font.
To find an itallic font, modify the properties of some text to find the font you want.
For information on creating your own fonts, see:
http://www.ptc.com/cs/cs_23/howto/kmf157/kmf157.htm
Following the directions on this I am having a little trouble understanding some of the steps. I copied and renamed the 2 .src files and show, then copied the compile_font.exe to the same directory. Do younow run the .exe file? When I did, nothing happened. I think I am missing something.
