Changing printer type
  • Thread starter Thread starter arroyopr
  • Start date Start date
A
arroyopr
Guest
Hello everyone:
How can i change my printer type destination defualt setting from postscript to windos_printer_manager?
In the drop-down menu (the down arrow), there is a list of printer files.
To set the default printer, use the config option plotter & set the value to the required printer setting (in this case MS Print Manager) & save the config.pro.
If you also edit the ms_print_mgr.pcf in your <loadpoint>\text\plot_config folder you can make your default printer and settings for it nearly anything you like.
DB
Thank you for ur reply:
Both suggestions are good onces.DELL_BOYurs was morepresice so i start from the bottom up. I edit the word doc. on the .pcf file to change my setting defualts to MS PRINTER MANAGER. Once again thank you.
Regards:
arroyopr.
