changing elements from famibly table according to parameters
  • Thread starter Thread starter robo_kk
  • Start date Start date
R
robo_kk
Guest
I can not find solution to my problem. Maybe it is not even possible but i would like to ask you :-)
I have an assembly of a pipe and a ring. The pipe is characterized by some parameteres: lenght, diamater, thickness...
Ring part is made as a family table, because it is more complicated. There are different gaskets, sizes, durability and so on.
And now, in an assembly, when i change the diameter of the pipe, I would like that after regeneration, some other instance will be chosen.
Is it even possible?
Cheers,
Robert
You can do this via Pro/Program.
thank you for the clue.
Unfortunately I don't have it.
Cheers.
Robert
Cheers,
Robert
I would make the pipe a family table as well, and then the assembly can have a family table that calls up the correct pair of parts. It's a bit more work, but it also insures that only standard size pipe is used - you can't accidentally design custom parts.
