Change the standard hole diameter
  • Thread starter Thread starter andy0046
  • Start date Start date
A
andy0046
Guest
I am using Proe 4. I am trying to create a standard hole with my desired diameter but i don't know how to change the diameter. Under the 'Shape', the diameter can not be changed. Anyone has any idea? thanks
"SHAPE" is a parameter ?.. through this parameter you wanto enter the diameter input ??
The standard hole uses hole table values for the diameter. If you want to change them you can setup *.hol files with the diameters you want or set the config.pro option hole_diameter_override to yes so you can change the value on the Shape tab.
Thanks guys
