Jun 1, 2021 #1 A arcturus Guest is there any way to change preselected commands? for example, i usually use "edge fillet". i want "edge fillet" is preselected instead of "shape fillet". Attachments edgefillet.JPG 15.2 KB · Views: 3
Jun 1, 2021 Thread starter #2 M MrCATIA Guest I don't know any way to save pre-selected commands. But CATIA V5 usually remembers the last command you used and displays that in the toolbar. It might help if you end your CATIA session with FILE + EXIT, instead of just closing the CATIA window.
Jun 4, 2021 Thread starter #3 R Rickyt Guest If you have a command that you frequently use, a simple macro to execute that command should work. Then you can add that macro to a new or an existing toolbar.
